Speedo isn't feeling good!
by sinbrad » Sat Aug 16, 2008 2:33 pm
Well today had the dash off to check my EM light. Once i checked and found it was a dodgy connection I fitted it all back in again. Now the speedo is reading about minus 40mph. No matter what I do it still heads back down under!! Here's a phot...
by Allys Cally » Sat Aug 16, 2008 2:38 pm
isn't there suppose to be a small pin for the needle to rest on?
is it cable driven or electronic speedo?
by sinbrad » Sat Aug 16, 2008 2:44 pm
electronic I believe?
by sinbrad » Sat Aug 16, 2008 2:50 pm
Just had another look and no sign of there being a pin for it to rest on. When I switch the ignition on the needle actually moves to that position. You can feel it forcing itself into that position and won't stop until it is???
by cornishtaz » Sat Aug 16, 2008 5:15 pm
The needle has a spring fitted to it this is why its going past the zero, the missing pin is to hold it at zero, if you look carefully there should a small hole where it should be. Does the speedo read correctly when driving?
cornishtaz
by sinbrad » Sun Aug 17, 2008 10:42 am
I see no hole? The speedo doesn't read correctly when driving, it reads about 30-40mph out. The first thing I done was look for anything that would stop the needle from moving past zero but nothing is visible even close up? Where do you think the small hole should be? Anyone got a photo?
by RobbieV » Sun Aug 17, 2008 4:06 pm
Just checked my speedo and there isn't a pin for the needle to rest on. ignition off and it just sits at the zero position.
by sinbrad » Sun Aug 17, 2008 4:52 pm
RobbieV wrote:Just checked my speedo and there isn't a pin for the needle to rest on. ignition off and it just sits at the zero position.
Thought as much, had me puzzled. In the end I let the needle rest where it's at and then took it off and repositioned it at zero. Seems to be working ok now. Just puzzled why it took to rest at the position that it did? Anyone else had this happen?
Users browsing this forum: Bing [Bot] and 36 guests
