Crank position sensor
what do you need to know westy??
The crank position sensor is situated next to the oil filter, jack up the front of the car, for saftey place on axle stands, the oil filter is on the front of the block and the crank sensor is to the right of it one small bolt 8mm or 10mm cant remember...then unplug fron the loom and replace
RAINMAKER
