ECU Fault Clearing
ECU Fault Clearing
Had a code 73 fault (airflow meter low voltage) bought and fitted a new airflow meter but still having the same problem as before.(erratic idle speed and lots of smoke)
Does anyone know if i need to do something to clear the fault codes?
Also got a code for the throttle position sensor before that and replaced that too.
Driving me crazy!!!!
Redtops Rule
