Favour from V6 owners
I'm after a favour from V6 owners. I trying to establish whether I've got a knock sensor fault or wiring fault, I'd like the resistance readings of front & rear knock sensors and the resistance reading of the connections back to the ECU.
Thanks in advance
Thanks in advance
cornishtaz
Not the sort of info many people would have i think !
Did you read through -
http://www.v6calibra.net/motonic/v6cali ... des.htm#16
http://www.v6calibra.net/common/v6calib ... sensor.htm
I can probably measure the resistance of the knock sensors for you tomorrow (once I get the bonnet up
As for the wiring to the ecu the Ohms reading (resistance) should be zero (or as close as) Any wiring fault will show as a high resistance or off the scale if a broken wire.
Have you got ecu code 16 or 17 then??
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
cornishtaz wrote:the rear knock sensor is open cct front one reads 1 ohm
Rear knock sensor open circuit is your fault (breakdown in the circuit).
The resistance reading of 1M ohm on the front shows the front one is not at fault as it has a complete path for the electrical current.
Try swapping the connectors to see if you get TC16.
I now own this one.
I now own this one.
V6Calibra.net wrote:16 Knock sensor 1 (front engine cylinder bank)
No change in voltage, bad wiring or bad sensor
17 Knock sensor 2 (rear engine cylinder bank)
V6Calibra.net/fault codes
I'm going by the bible...
I now own this one.
I now own this one.
cornishtaz wrote:Just wanted to confirm the fault as I know the rear sensor is hard to get at.
The wire runs behind the alternator mounting bracket as well. I found this out after I'd bolted everything on...
I now own this one.
I now own this one.
Right, went to the car today with my trusty multimeter and this is what I got...
Front knock sensor wiring through ecu 1.01 MOhms
Front knock sensor o/c
Rear knock sensor wiring through ecu 1.00 MOhms
Rear knock sensor o/c
Seeing as I have no ecu codes, I can only conclude that a knock sensor with an open circuit reading is working ok.
Perhaps when the sensor picks up 'knock' then it completes the circuit and the ecu acts accordingly.
The only other path I can suggest is quoted above from V6.net, disconnecting one knock sensor at a time and seeing which codes get flagged by the ecu.
V6Calibra.net wrote:It has been reported that in some cases the front and back knock sensors are in the opposite order. In these cases a fault code 16 actually refers to the rear engine knock sensor (at back of engine back nearest windscreen). If unsure check by disconnecting each sensor in turn and driving as short distance to check which fault code has been triggered.
I now own this one.
I now own this one.
Just been out this morn and done some checks, I cleared all the faults codes by disconnectng the battery last night and confirmed this by flashing them this morn and none stored. I then disconnected the rear knock sensor ran the engine until ECU light came on and re-read the fault codes and got 16 and 17, cleared the codes again re-connected rear sensor ran engine until ECU light came on again read codes and got 17 so it looks like my front knock sensor is knackered. Vaux want £38 so will be going to autovaux, £23, and not use the car for the rest of the week(time to get the push bike out), and to think I had 2 of these before I moved house and they got mixed up with the crapin the old garage and now can't find them.
Thanks for everyones help.
cornishtaz
Users browsing this forum: Bing [Bot] and 7 guests
