HELP!!!! Ignition barrel problem!
by dave_se2 » Fri Oct 10, 2008 7:29 pm
Hi guys and gals. My ignition barrel has just gone t**s up! If i change just the barrel and key for a second hand one will i need to get the transponder key swapped over from my old key? Does it even have one? How do i tell? Please help as i need to go to scrappy to get one in the morning. Cheers, Dave.
dave_se2
by vcab1 » Fri Oct 10, 2008 7:36 pm
i just recently had this problem, when you take the cowl off is there a black
box around the ingnition ( transponder)
if yes, you need to take the chip out your old key and put it in your new one.
vcab1
by dave_se2 » Fri Oct 10, 2008 7:39 pm
Cheers. When you say black box around the ignition, which end of the barrel,on top,underneath?
dave_se2
by vcab1 » Fri Oct 10, 2008 7:41 pm
it fits around the barrel where you put your key, with a square box under it, all one piece
vcab1
by dave_se2 » Fri Oct 10, 2008 7:43 pm
Cheers mate!
dave_se2
by vcab1 » Fri Oct 10, 2008 7:45 pm
thats if you have one, how old is your calibra. i think they started fitting them on 1995+ cars
vcab1
by tazz666 » Fri Oct 10, 2008 8:06 pm
dave your se2 wont have the transponder as it is a red top and the transponders were fitted on ecotecs onwards so 95 onwards
tazz666
by Johnny A » Fri Oct 10, 2008 9:35 pm
My uncles cav was brought to me for a service, the ignition barrel nuked itself internally AGAIN. First time it happened I replaced the entire unit with a second hand one.
Its gone again! It means you cannot turn the key - it refused to turn. This means you cannot get the ignition into position 1 to slide the barrel out.
Power drill is your friend. I made him spend £60 and buy a brand new unit this time.
The immobiliser is a flat black ring thats hooked on the end of the ignition barrel casing. The ring has a box attached to the bottom of it.
If you have this you need to swop the chips over.
Johnny A
by DC 12v » Sat Oct 11, 2008 10:06 am
Raylentless stuck his key in my ignition barrel,
I'll skip right to the end in saying that there is now a corsa one there!
DC 12v
by dave_se2 » Sat Oct 11, 2008 8:50 pm
Thanks everyone, i've sorted it for now. Fitted a second hand one just to get by for now but i will buy a new one asap! And Taz666, you were spot on!! No imobiliser!
dave_se2
by tazz666 » Sat Oct 11, 2008 8:51 pm
at least you have it sorted mate well done
tazz666
