cooling fans
cooling fans
by odbod » Sat Nov 01, 2008 9:13 pm
my car fans are coming on at 90c and not at the 100 c but the car is running fine and the water is hotter then the gage is saying eney help on this i would be greatfull cheers odbod
by superfox233 » Sat Nov 01, 2008 9:28 pm
100c is the boiling point of water..if u allow it to reach that temp, ur cooling system would certainly blow! fans shud cut in before it gets chance to reach 100c.. sounds fine to me??
superfox233
by BazV6er » Sat Nov 01, 2008 10:02 pm
my v6 at full temp runs about 90-95 and then fan kicks in so sounds normal
by RobbieV » Sat Nov 01, 2008 10:08 pm
superfox233 wrote:100c is the boiling point of water..if u allow it to reach that temp, ur cooling system would certainly blow! fans shud cut in before it gets chance to reach 100c.. sounds fine to me??
It won't blow at 100c.
On the V6,
Thermostat starts to open at 92c and is fully open at 107c.
Main fan & booster fan kicks in at 100c and goes of at 95c.
At 105c auxiliary fan (booster) kicks in.
And Expansion Tank Cap rated to 123 deg C and 1.5 bar pressure.
by cornishtaz » Sat Nov 01, 2008 10:19 pm
My V6 sits at 92 and fan is on at 100 down to 95 aux cuts in mainly once I've stopped
cornishtaz
by odbod » Sun Nov 02, 2008 1:52 am
that what mine did do but now cuts in at 90 that well low for that it should be 100c to 95 then they should cut off mine should run about 90 to 95 but when sitting in the traffic it would go to the 100 and come back down so could this just be temp sencer or the rad fan cencer which cut the fans in cheers odbod
