Any ideas?
Any ideas?
by vinny_69 » Wed Nov 19, 2008 6:35 pm
the misses keeps moning about the position of the window switches (the fact we both have fecked shoulders) and i was thinking it wouldnt be to hard to reposition em.
So i ask my fellow cally nuts,,,,, where would be the best place to put em?
vinny_69
by big_gordy » Wed Nov 19, 2008 6:45 pm
move em into the dash or do what aldo done into the door cards!
i moved the sunroom switch the where the light switch is on the left...
by vinny_69 » Wed Nov 19, 2008 6:52 pm
just found an old post about mk4 astra switches in the door cards,but im still open to suggestions :monkey:
vinny_69
by Griz » Wed Nov 19, 2008 6:53 pm
tbh l did think they were poorly placed even without the fecked shoulder :)
Griz
by vinny_69 » Wed Nov 19, 2008 6:56 pm
would this switch work peeps?
vinny_69
by evilcally » Wed Nov 19, 2008 9:07 pm
Yes probably or you could move the standard ones, the lower part of my centre console between the seats is a vectra one. to fit everything I flipped the wiring that runs in front of the seats over and secured it along the bottom of the dash and fitted the switches into the centre console in the area to the right of the radio (by drivers left knee) if you cut accross crease in middle standard switch it takes up less space and can be slotted into a hole cut in this area.
or you can buy the cavvy switches and try to trace the wires for the motors in the doors and connect everything up.
good luck.
evilcally
by vinny_69 » Thu Nov 20, 2008 1:05 am
:-k i will have a play around see what i can come up with
vinny_69
