Hall effect switch - Where is it? How can I fix it?
Bodykit without Lowering
by jonnyboy » Thu Jul 15, 2004 9:19 pm
Hey guys.
I started the car and I got a dam light on!! So I checked the codes, its given me 94 - Hall effect switch voltage high.
I thought it was the plug on the side of the dizzy, but it looks fine, I've sprayed it with WD40 and its still the same. I am right in what I'm doing? How can I sort it?
The last week or 2 it has felt a bit lumpy on idle, and when cold kinda hessitates. Does this sound familiar?
Will it do any damage to my Carly?
Cheers fellas!!! And fella-esses!!
jonnyboy
by leegsi » Thu Jul 15, 2004 9:26 pm
Hall effect sensor is the sensor on the side of the dizzy
leegsi
by jonnyboy » Thu Jul 15, 2004 9:33 pm
Yeah I know, I've cleaned that but its not done anything
jonnyboy
by jonnyboy » Thu Jul 15, 2004 10:08 pm
anybody?
jonnyboy
by SukySaggi » Fri Jul 16, 2004 2:13 pm
I had coolant temperature voltage too high and it turned out that there
was a break in the wire to the coolant temp sensor.
All I can suggest is check your wires for a break.
SukySaggi
