dodgy indicators....
ok..so my hazard light has never worked.
and every so often my indicators(like its happened 3 times in 2 yrs [img]/tongue.gif[/img] )dont flash, the light on the dash comes on but doesnt flash, and outside the lights are either totally off or totally on....
and i just replaced the hazard switch and all was fine for a few days but now my indicators dont work (doing the same as above).
basically i have checked all fuses and even bought a new flasher unit (goes into the fuse box) and still no joy.
the symptoms are : when either putting indicators on or harard lights, the indicator light on the dash comes on and doesnt flash, and outside nothing happens at all...any ideas people ?[img]/sad.gif[/img][img]/sad.gif[/img]
blueraven
Hmm, not sure, I thought there was only the one in the fuse box. Have you checked ALL the indicator bulbs (front and back) , maybe a loose bulb/connection would cause it, tho I'm guessing on that one.
I assume the replacement flasher unit is 'known good' , i.e it's been seen working on another car..?
Leigh
