Heated Seat Prob
Heated Seat Prob
by eco16v » Wed Feb 25, 2009 8:22 pm
Can anyone tell me how to check if the heat pad is faulty on my drivers seat?
eco16v
Re: Heated Seat Prob
by vinny_69 » Wed Feb 25, 2009 8:24 pm
if you have checked the wiring and its still not working its the pads
vinny_69
by eco16v » Wed Feb 25, 2009 8:24 pm
How do you remove the pad to replace it?
eco16v
by v6-calibra » Wed Feb 25, 2009 8:25 pm
Have u checked the wiring by the side of the seat.
Where the seat hook catches the lower half of the seat.
v6-calibra
by v6-calibra » Wed Feb 25, 2009 8:26 pm
I have seen a replacement pad kit for £110 per seat but its a carbon fiber replacement for better displacement of heat etc
Id include the link but cant remember where i saw it.
v6-calibra
by eco16v » Thu Feb 26, 2009 7:41 pm
Didnt realise there was wiring in the side of the seat mate.
eco16v
by 1llusion » Sat Feb 28, 2009 5:01 pm
Near the seatbel connector is a wire that connect the 2 heatihg pads.
Back and bottom part.
This set of wires get a lot of friction from the moving of the seat forward in order to let people sit in the back.
To much friction and the wires snap.
Just get your hand in there (Do not get stuck LOL) and try to find the wires.
If found check if they are still in 1 piece.
huge chance they are not.
If it is OK than your heating my be broken.
1llusion
by sinbrad » Sun Mar 01, 2009 11:52 am
eco16v wrote:How do you remove the pad to replace it?
It's easy enough to remover the pad in the back part of the seat but would like to know how to remove the pad from the bottom part of the seat? Does the leather just lift as per the back and expose the bottom pad?
by tazz666 » Sun Mar 01, 2009 12:50 pm
you have to unclip the clips from under the seat base, and it makes the job easier if you if you take off the seat frame :D
tazz666
