calling on any electronic buffs!!!!
right wgere do i start...lol i will try my best to describe what im looking for
i am looking for some sort of resistor,relay or swich and this is what it is for
i want to have a row of leds light up but not to there full brightness and when i press on a switch they come on full power!
btw power sorce is 13.4 or 12v
is this possible????:cry:
Re: calling on any electronic buffs!!!!
You can get Variable Resistors, like this,
http://uk.rs-online.com/web/search/sear ... 4294955100
And then add a control knob,
http://uk.rs-online.com/web/search/sear ... 4294956691
Wasn't there a unit made for the afterburner lights which lit the brake leds at half bright for the sidelights then full bright when the brakes were applied??
Can't remember the blokes name now
(Simon??) he's got the black/red turbo and it's been in Total Vauxhall...
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&binCount=308&Ne=4294957561&N=4294963016+4294956691[/quote[/url]]Mark1 wrote:You can get Variable Resistors, like this,
[url=http://uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&binCount=308&Ne=4294957561&N=4294963016+4294956691
what ones all i see is a website! i diont know what im looking for!!!!
I use a 1K variable resistor from maplin for controlling the 12 volt fans on my PC. If you use that you can fine tune the voltage. Then just add a switch to kick the resistor in or out the supply loop.
