HID query
HID query
What is the best way of connecting up the pink wire. Mine doesn't disconnect from the bulb surround so i was thinking of cutting and using a small electric block. What have you other guys done? i don't possess a soldering iron by the way.
Re: HID query
Do you mean the red (live) wire from the HID kit ?
Re: HID query
yes, not the one that goes into the wire that was on the back of the bulb, the one that goes to the bulb holder
Re: HID query
The red (live) from the HID kit connects to the yellow wire which is connected to the standard headlight bulb.
Re: HID query
sorry Robbie, i meant the other wire
. Colour blind
Re: HID query
The only other wire will be the black which is the earth, just connect that to another brown wire inside the headlight.
If you still have problems then just follow the *how to* guide
http://www.clubcalibra.net/knowledge/kb_show.php?id=22
Re: HID query
thanks Robbie, got there in the end. will be fitting them once i've done the water pump
