trip comp
Re: trip comp
depends mate some callys have the yellow plug and switch loom fitted anyway
what year and model bud?
vinny_69
Re: trip comp
remove the clock and have a loog for a big yellow plug taped behind the loom.or just pop the glove box out.
if you do have that you might also have the switch loom in the centre console next to your lekky window socket.if you do its just plug and play
vinny_69
Re: trip comp
if you do have the yellow plug but not the switch loom let me know as i think i have a loom knocking about some place
vinny_69
Re: trip comp
picked up car and yep i got a yellow plug
so whats the other plug i need to check for?
paul.p
Re: trip comp
remove the centre console by the handbrake and where your window switch plugs into you should have a plug with nothing in it,thats for your trip computer switch
chances are you will have to drimmel your coin holder out as your switch fits there
hope that helps
hope that helps
vinny_69
Re: trip comp
vinny_69 wrote:remove the centre console by the handbrake and where your window switch plugs into you should have a plug with nothing in it,thats for your trip computer switchchances are you will have to drimmel your coin holder out as your switch fits there
hope that helps
Coin holder..... Did anyone actually use this as a coin holder without crawling around the footwells looking for your coins that took off when you broke for the traffic lights
Re: trip comp
doesnt look to cool when all you can afford is 1p pieces to put in it either eh Vinny
Re: trip comp
