**HELP** Both windows stuck down!!
My windows havnt worked for a couple of months now, but as if by magic, they started going up and down this week.
BUT! I wound them down and now they are totally unresponsive to the buttons!! THEY WONT GO BACK UP!! (major security breach...)
Is there a way to manually wind them back up if i take the doorcards off??
PLEASE HELP!!
PLEASE HELP!!
superfox233
Re: **HELP** Both windows stuck down!!
D o you have the overide button on center console???
just wondering if the windows are sensoring something in the way and stopping.
Will
Will
WillsToy
not sure if its a seperate circuit or not, but you could try shutting hte windows with the key, ie hold the key at 45degrees anticlockwise for 30seconds.
Took doorcards off and got the power probe in! Its appears to be the red wire (constant feed). As soon as i gave it a 12v feed from the probe, they worked!! Must have a brake in the wire behind the dash....
Does the central locking motor have a constant feed that i can 'share' with the window motor??
superfox233
I think the Cl is a constant feed and switched on the -ve side, but I wouldn't put that kind of load on what is prob a thinner wire for the CL
have you checked the door connectors? where they pass into the doors? the weather shield is poor and often when you remove the connector water pours out lol. give them a good clean up and dry up and try again.
