H/light switch assem. removal?
Hi guys, can someone tell me how to remove the h/light switch assem.?. I want to fit some extra lighting, and use the pull knob switch for the on/off. I can get the right side out, but not the left. Thanks.
ArcticHeat
Re: H/light switch assem. removal?
Turn the switch to the upright position. Pull the switch part out. Underneath there is a small hole. Insert small screwdriver or drift into hole and release clips. Body should then pull out easilly.
Tim2001
Thanks for your help. I'll try it tomorrow..cheers
ArcticHeat
