Cally LE won't start
by k16sst » Fri Jul 31, 2009 1:15 am
Hi guys, i was hoping some one could help me out here.
My LE turbo just wont start, i think its a fueling problem,, I had to call out RAC they had a look at it but could not fix it, but suggested possible fuel pump failure?? as there is no fuel coming to the fuel rail? So i replaced the fuel pump which was inside the fueltank, but nothing and I cant hear the fuel pump either. Am I doing some thing wrong..
Or could it be something like, fuel relay, fuel regulator...etc..
Any tips or ideas would be grateful.
k16sst
Re: Cally LE won't start
by Callyman » Fri Jul 31, 2009 7:49 am
As Kenny said, check the relay.
Get the kick panel off, get your head down there and you should hear a faint clicking from it when you turn the ignition on/off. If not, replace it.
by Callyman » Fri Jul 31, 2009 12:38 pm
If the relay is dead the pump wont do anything.
Get ya head down into the footwell and see if you an hear it cleck when you put the ignition on/off.
It's a very easy and fairly cheap fix, I'd always suspect the relay 1st.
