cranksensor where?
cranksensor where?
by red8valve » Sat Aug 15, 2009 11:46 am
hi where is the the crankshaft sensor on a 2 litre 8 valvle c2one engine cheers
red8valve
Re: cranksensor where?
by MarkV6 » Sat Aug 15, 2009 6:55 pm
It should be located on the bottom left of the engine block as you look under the bonnet. E30 torx bolt holds it IIRC.
If you need pics, reply here...
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by red8valve » Sat Aug 15, 2009 7:11 pm
yes mate some pics would be very helpfull cheers
red8valve
by MarkV6 » Sat Aug 15, 2009 7:22 pm
Hope this gives you some idea...
Also it could be an 8 or 10mm bolt, torx bolts were used on the later models.
I now own this one.
by MarkV6 » Sat Aug 15, 2009 7:26 pm
Re reading the tech stuff, if you can't get it through the hole in the engine mounting, you will have to remove it or cut the old wires and re route the new sensor wiring somehow.
I now own this one.
by red8valve » Sat Aug 15, 2009 7:27 pm
thanks very helpfull
red8valve
