cliffard imobiliser
cliffard imobiliser
by BIG DAN » Wed Jan 06, 2010 4:27 pm
after alot ov time and me gettin stressed alot lol think its my imobiliser that is stopping fuel gettin through does anybody have an idea where cliffard would put the bloody thing because i cant find anything anywhere
BIG DAN
Re: cliffard imobiliser
by Callyman » Wed Jan 06, 2010 7:38 pm
Most likely place is behind the glovebox
by BIG DAN » Thu Jan 07, 2010 4:56 pm
found it but cant seem to find the imobiliser wire as it is all wraped up tidy but it i unplug the box will that get rid of the alarm totally therefor de atcivating the imobiliser ???
BIG DAN
by Fraz » Thu Jan 07, 2010 5:37 pm
doubt it as they interrupt the supply wire for the fuel and ignition. so if its un plugged you wont complete the circuit
by BIG DAN » Thu Jan 07, 2010 6:35 pm
so how did he sort it because im not getting fuel at min ???
BIG DAN
by Callyman » Thu Jan 07, 2010 6:51 pm
Could it not just be the pump relay?
by the painter » Thu Jan 07, 2010 6:52 pm
Dan have you done a web search? there must be alarm questions and answers........ just a thought.
the painter
by BIG DAN » Thu Jan 07, 2010 7:29 pm
no its not the pump relay or the pump itself they have all been checked witch makes me think it could be the imobiliser im not 100% yet but think tht all it could be know so how did you get it too work then ally ??? please share as im getting stressed with it now
BIG DAN
by Callyman » Thu Jan 07, 2010 8:26 pm
When you crank the engine, does the engine fault light flash?
by Allys Cally » Thu Jan 07, 2010 8:38 pm
the alarm was missing the valet switch on the se9 once that was fitted it worked.
i had a problem with my 8v 2 years ago where my throttle position sensor went, basically the car would crank but wouldn't fire. at first i thought it was the fuel pump relay or pump. i would do a paperclip test and check for codes ( i think this is what Andys pointing towards )
by BIG DAN » Thu Jan 07, 2010 8:45 pm
never done the paper clip before how would this be done ??
BIG DAN
by Callyman » Thu Jan 07, 2010 8:53 pm
http://www.topbuzz.co.uk/info/fault_cod ... _codes.htm
If the light flashes when cranking, it is likely to be the key chip/sensor at fault.
Users browsing this forum: No registered users and 76 guests
