Where is the ECU??
Where is the ECU??
by skitz_1184 » Fri Jan 22, 2010 9:31 pm
Where is the ECU on the Calibra turbo and how do i remove it?
Lee
skitz_1184
Re: Where is the ECU??
by Allys Cally » Fri Jan 22, 2010 9:37 pm
its behind the drivers side kick panel above the fuel pump relay, its held on with 3x 8mm screws. and the top one is a tight bugger to get to if you have big hands :)
