found a plug!!
found a plug!!
FOund this little bugger under the airbox, someones shorted it out by sticking a bit of wire in there, as far as i can see it goes off to the loom somewhere behind the engine, have a look at the pics and see if you can make sense of it?
Re: found a plug!!
Ill see what happens... why do people do these things!?!
Re: found a plug!!
Tell me about it, mine has been abused too, bits broken off, not in the right place, bodged repairs.. Animals!
MarkSE7
Re: found a plug!!
thankfully mine still runs ok, but it is concerning when you find plugs just tucked away like that, whoever did it didn't even have the sense to cover the wire over with some insulation tape... cowboys!
Re: found a plug!!
ive not checked yet, im just here having a cuppa... will venture outside in a bit, once my eyes will take the light...
Re: found a plug!!
Just had a quick look on mine, can't see anything that would be that long. Could be from a knock sensor but can't see without having the car in the air.
MarkSE7
Re: found a plug!!
it looks like the rear knock sensor, would have thought it would put up a fault code doing that
Re: found a plug!!
right... I took the wire out and fired the car up, EML didnt come on... tried doing the paperclip test with the wire in and out, no faults...
The wires going to the plug are Brown and Brown/Green or it could be Brown/Yellow, they are very dirty and faded...
Been looking at the wiring diagram in the haynes and really all I can see is the Inlet Manifold Temp Sensor that uses Brown/Green...
I'll keep investigating...
Re: found a plug!!
could it be the lambor sensor with the wroung plug on the end. can you find what is on the other end or any other plugs that arent conected
Re: found a plug!!
I ran my hand down the cable as far as i could and it seems to join up with the rest of the loom, I would need to get under the car to have a proper look as to where it goes...
I thought the lambda had three wires on it?
Re: found a plug!!
yee it should but it was the only thing i could think of that is that long and comes up the back, i dont know the manifold on the 20L that well but is there a not a sensor down the back ICV or somthing like that is it conected
Re: found a plug!!
looks like the oil level sensor wire.
Re: found a plug!!
Still trying to find out what the hell this plug does... will be having yet another look tonight...
