indicators not workin
by stevo turbo » Fri May 14, 2010 10:48 pm
right one of the next jobs need doing is the indicators dont work. i automatially got a workin relay and fitted it and found no difference. but also found out the hazzards and all bulbs are working! when you switch the indicators on the light for it comes up on the dash but its just constant. anyone got any ideas? indicator stalk?
Re: indicators not workin
by v6 steve » Fri May 14, 2010 11:00 pm
check the earth at the back of the car
by Allys Cally » Fri May 14, 2010 11:29 pm
could be a faulty stalk, do you know anyone with an astra or cavalier that you could try their indicator stalk in your car to rule it out. i think the vectra b stalk is the same as well.
by cally8valver » Sat May 15, 2010 9:44 am
def earth at back or indicator stalk
cally8valver
by stevo turbo » Sun May 16, 2010 11:31 am
gonna try this earth possibility- has anyone got a pic of where it is. i clicked on yesterdat that my corsa b uses the same stalk so tried and no difference. so stalk is ok relay is ok hazzards lights work fine but havent tried a different switch yet. so if there are any other ideas im gonna try this earth. cheers for the replys
by stevo turbo » Sun May 16, 2010 10:08 pm
found it! hazzard switch connections. removed cleaned terminals and refit- easy as that! :dance:
