Little f
Little f
by chris_p » Tue Jul 27, 2010 7:59 pm
Why does a little f keep coming up on my clock?
Re: Little f
by Callyman » Tue Jul 27, 2010 8:01 pm
It means there's a fault.
Does it still work ok? or is it just an F?
If so it's poss outside temp sensor.
Mine has a very small F in it when ignition is off, but goes when i start it.
Re: Little f
by chris_p » Tue Jul 27, 2010 8:08 pm
Erm everything works fine (touchwood) just this little f flash's prettymuch all the time now, so its just a fault with the trip/clock comp then?
Re: Little f
by Callyman » Tue Jul 27, 2010 8:10 pm
Try removing the plug from the rear of the unit and refitting it, that sorts mine out for a while.
Re: Little f
by chris_p » Wed Jul 28, 2010 9:06 pm
Will do thanks for that.
