Rear side lights not working, but all the rest do
by wcKo » Sat Sep 11, 2010 1:36 pm
My rear side lights have stopped working on the drivers side. All the other lights work its just the 2 bulbs for the rear side light dont. I have replaced the bulbs, checked the fuses, replaced fuses 1 + 21 any case (rear side light fuses - 21 being the drivers + 1 passenger), checked earth on these bulbs, checked wires on back of fuse box, replaced rear light and still nothing. Any ideas guys??
wcKo
Re: Rear side lights not working, but all the rest do
by tazz666 » Sat Sep 11, 2010 2:13 pm
check the connectors on the bulb holder where it makes contact with the light
tazz666
by john.ness » Sat Sep 11, 2010 2:29 pm
happened to me wi brake lights one side wasnt workn replaced bulb it was a broken wire by the bulb holder!!
john.ness
by wcKo » Sat Sep 11, 2010 2:32 pm
tazz666 wrote:check the connectors on the bulb holder where it makes contact with the light
john.ness wrote:happened to me wi brake lights one side wasnt workn replaced bulb it was a broken wire by the bulb holder!!
Replaced the whole light so its not the bulb holder unless I have 2 lights both with the exact fault and same rest of the bulbs work on both sets
wcKo
by Fraz » Sat Sep 11, 2010 7:38 pm
best get a meter or test light and see if your getting a live at the connector that plugs into the rear lights, what one is not working the drivers side or passengers side
by wcKo » Sat Sep 11, 2010 9:20 pm
Drivers side, starting to get on my t**s now as cant drive at night as dont want to get pulled over
wcKo
by Fraz » Sat Sep 11, 2010 9:32 pm
wires for the rear lights go to the passenger side first then go across the back to the passenger side, could be the wires have been cut somehow, if all else fails just run a wire from the drivers side over
by wcKo » Sat Sep 11, 2010 9:47 pm
Fraz wrote:wires for the rear lights go to the passenger side first then go across the back to the passenger side, could be the wires have been cut somehow, if all else fails just run a wire from the drivers side over
Good Idea mate will try that. It did have a tow bar whic was removed but that was months ago. Will have a fiddle in the passenger side then if all else fails, a quick bridge fron one side to the other and then will forget about it lol
wcKo
by Calibra_Mike » Sun Sep 12, 2010 10:45 am
sounds like a bad connection/broken wire...
by v6 steve » Sun Sep 12, 2010 11:24 am
have you tested the wires with a meter as it might be the switch i would check to see if you have a live feed at the back of the switch
