LCD speedometer problem
I've pluged in LCD speedometer earlier, but several functions doesn't work:
1) the turn signal on speedometer doesn't work
2) the high-beam headlights signal doesn't appear on speedometer
can you tell me how to plug it in the correct way?
I thin the problem lies in the plug, there are unplugged wires left.
can you help me plug it in?
Chipa
Re: LCD speedometer problem
for the turn signal you need to run two new wires from your Indicator Stalk
Indicator Left Black/Green to pin 14 of the large black connector X55
Indicator Right Black/White to pin 12 of the large black connector X55
the high beam you use the white wire from your original big black connector and it goes into the terminal 15 of the X55 connector
