CTS Sensor LET?
CTS Sensor LET?
hi,
Does anyone know if the CTS sensor can be faulty but not show a high/low voltage on the ECU fault codes?
Regards
S
Regards
S
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
Re: CTS Sensor LET?
if yoi think its faulty...............just change it they are only a few quid
Re: CTS Sensor LET?
ive had more than one over the years thats been faulty out of the packet from vauxhall!!
Vxlgsi
Re: CTS Sensor LET?
CTS Sensor does degrade in signal response with time, a failing CTS does not always raise a fault code it just provides the ECU with an incorrect coolant temperature. Will eventually supply a bad reading out of ECU tolerance (which is when a code is raised). Symptoms can include poor start, rough idle and rich running/poor petrol economy.
Re: CTS Sensor LET?
Cheers lads!
Seems to run bad when hot. Everything else (mechanical) is ok. No ECU code but its like a rocket when cool which makes me think CTS is out.
Will change tomorrow and update the thread.
Regards
S
Regards
S
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
