ignition timing v6
ignition timing v6
by rich30mex » Sun Jun 05, 2011 5:14 pm
what sets the spark timing on a v6 and can it be changed
Re: ignition timing v6
by Fraz » Sun Jun 05, 2011 5:44 pm
the ecu does that
by rich30mex » Sun Jun 05, 2011 6:15 pm
Fraz wrote:the ecu does that
thanks think thats the problem the ecu
by Callyman » Sun Jun 05, 2011 7:24 pm
What problem are you having ?
by Fraz » Sun Jun 05, 2011 7:38 pm
callyman wrote:What problem are you having ?
have a read
viewtopic.php?f=12&t=46137
by Callyman » Sun Jun 05, 2011 7:53 pm
Is it like a misfire on idle?
by RobbieV » Sun Jun 05, 2011 7:56 pm
Thread moved to the correct part of the forum :)
by Callyman » Sun Jun 05, 2011 8:01 pm
Rich, I've just skim read the other thread abut this problem, can you confirm if you have changed the ECU Coolant Temp Sensor or not?
by rich30mex » Sun Jun 05, 2011 8:32 pm
callyman wrote:Rich, I've just skim read the other thread abut this problem, can you confirm if you have changed the ECU Coolant Temp Sensor or not?
not sure were is the coolent temp sensor iv changed loads of bits
by rich30mex » Sun Jun 05, 2011 8:33 pm
RobbieV wrote:Thread moved to the correct part of the forum :)
thanks
by Callyman » Sun Jun 05, 2011 8:54 pm
Its the blue sensor in the coolant bridge circled.
You should be able to get to it without removing the inlet, tbh it's the first thing i would of changed as it's cheap to buy and can cause havoc without spitting up a code.
by rich30mex » Sun Jun 05, 2011 9:19 pm
just been out and had a look theres 2 blue conectors is it the 1 what sticks up or is it the 1 layed on its side
by Callyman » Sun Jun 05, 2011 9:21 pm
Its the bigger of the two, (Horizontal) the single connection one is for the temp gauge, the bigger one is the temp sensor, I think it's a two wire jobbie.
