Remounting the alternator
has anyone ever or has anyone ever thought about putting an other alternator on to a v6 in place of the air con pump, i cant see it being to much of a hassle just need a bracket made up so the belt still fits,
Re: Remounting the alternator
What you want 2 alternators for
Sent from my HTC Wildfire S A510e
could i not put a bigger pully on to stop the slipping or would that cause it too fast and F*** up, the reason i need to do somthing is the install takes more power out than i can put back into the batterys when its at shows and only on idle
1 hour or so depends on what all is turnned on 3 x amps, ps3, 19" tv 2x7" tv smoke machine 8x speakers and sub + all the leds
Its a generator you want to install
get a split charger and put another battery in and make sure its a gel on so if it runs down completly flat it wont damage it
upgrade the alt and upgrade the batery terminals and wire...
http://www.driverstechnology.co.uk/car-batteries.htm
big_gordy wrote:get a split charger and put another battery in and make sure its a gel (i think im sure correct me if im wrong !) on so if it runs down completly flat it wont damage it
upgrade the alt and upgrade the batery terminals and wire...![]()
its got a marine battery in the back all ready with a split charger and an uprated 120watt alternator, it could do with a larger gauge wire for the split charger but there still wont be enough power from one alternator, remember when at shows its only on idle
in the early 90,s on big installs, they used to use 2,to 3 + alternators on there installs,so maybe getting in touch with some one from a company like fusion,vibe or someone who build installs
tazz666
try paul at source sound sheffield he nows his stuf im sure he will help
http://sourcecars.com/
remember hes the 1 who was going to us a discount but someone couldent be 4rsed to get intouch with him
i think i know what it do i just wanted to know if any one els has done it
Users browsing this forum: Bing [Bot] and 1 guest
