Radio/cd ignition switch
by RICHSE4 » Sun Aug 15, 2004 9:18 pm
is it possible to use the radio/cd on the ignition key 1,mine will only work when ignition is full on or when engine running,if so how? richard.
RICHSE4
by LewJamBen » Sun Aug 15, 2004 11:01 pm
All radios need two feeds. Red=12v battery, and Yellow=Auxillary switch in ignition barrel. To enable use without even using your key, connect both of these wires of the radio loom into the red wire from the car loom. If you have any probs, PM me.
LewJamBen
by RICHSE4 » Mon Aug 16, 2004 1:52 pm
thanks for reply,but will that mean i will have to turn it on and off on the head unit?didnt want to do that.richard
RICHSE4
by leegsi » Mon Aug 16, 2004 8:31 pm
Have a look here: <a href="http://www.cavweb-forums.co.uk/showthread.php?t=4055" target="_blank">http://www.cavweb-forums.co.uk/showthread.php?t=4055</a> (Might have to register)
leegsi
