total closure on calibra
hi on my vec b i done a mod to close the windows when you lock it just by joining 2 wires as you can see in this thread http://www.vauxhallmodified.com/showthread.php?t=613
is there a mod like this for the calibra?
Re: total closure on calibra
the windows go up with the key in the lock, all you do is hold the key over towrds the locking side
if you wish to fit a remote locking kit then you can get the windows to go up as well with some of them like this one
http://www.ebay.co.uk/itm/REMOTE-KEYLES ... 231eb96993
Fraz wrote:the windows go up with the key in the lock, all you do is hold the key over towrds the locking side
they dont go up on mine how can i fix it?
do they go up with a one touch on the button ?? if not you will have to reset them by putting the windows right down but keep your button depressed when the are at the bottom for a few seconds, then do the same going up
they should then open and close with a long held press of the button (one touch)
they should also close with the key (if they are reprogrammed as above) by locking the drivers door and hold the key slightly over to the locking side
Fraz wrote:do they go up with a one touch on the button ?? if not you will have to reset them by putting the windows right down but keep your button depressed when the are at the bottom for a few seconds, then do the same going up
yeah the one touch works but they dont go up when locking it
Mine go up with my remote locking Cobra Alarm
Robs-se wrote:Mine go up with my remote locking Cobra Alarm
think i`m goin to have to get 1 i miss the remote locking too
