Anyone know the pin outs on the fuel tank large top plug?
by Richiem » Tue Nov 25, 2014 10:01 pm
Guys i tracing back the wiring on the cali tomorrow starting from the fuel pump which i already know has no live coming in. Next step is the large white plug on the top of the fuel tank! Wondered if anyone knew which colour was live and which earth for the pump?
Seem to be struggling with finding this info online
Cheers rich
Ps/ i did manage to find this which might be usefull>>Image
Im sort of seeing it might be the red/ blue 4mm ( no4) that goes to the pump for the live!
Re: Anyone know the pin outs on the fuel tank large top plug
by Richiem » Tue Nov 25, 2014 11:19 pm
OK, so the colour is the same anyhow! Nice one!
by wuffy » Wed Nov 26, 2014 7:49 pm
Sorry to hijack your thread Richiem but if that diagram is for the ecotec do you need to change both relays on the ecotec? im having similar problems of what seems an intermittent misfire/lack of power, ive changed just about every sensor but still the same, so now im thinking along the fuelling, injectors, fuel pump relay, fuel pump route.
1996 ceramic blue 16v ecotec
by Phill » Wed Nov 26, 2014 10:26 pm
There are 2 purple relays in the kick panel. I removed and kept them when I stripped the old girl.
by wuffy » Wed Nov 26, 2014 11:38 pm
I got the fuel pump relay from autovaux, they didn't ask if I wanted or needed coil pack/injector relay also, so there is a separate relay for the injectors/coil pack?
by wuffy » Thu Nov 27, 2014 12:07 am
Hmmm, I guess I will find out when I take the kick panel off.
