No fuel pump
No fuel pump
by odbod » Wed Sep 06, 2017 5:13 pm
Hi I have a v6 calibra which does not start it has a good spark to the plugs but it seem to have no fuel coming up from the pump I have put a new relay and shorted 30 and 87 b out but still not working I am trying to fined out what the wire brown and blue wire goes as it come of the relay I think 85 and 85b if some one could help this would be great as I won't to put it back on the road for next year and have some thing to sort out
Cheers Richard
Re: No fuel pump
by Cliff » Wed Sep 06, 2017 8:31 pm
Do you have pressure at the rail when cranking? If not, is there power to the fuel tank pump - meter it at the pump/tank top.
Re: No fuel pump
by odbod » Wed Sep 06, 2017 10:59 pm
No fuel at the rail and it sounds like it mite be the pump or the wiring to the pump
Re: No fuel pump
by craigyboy » Sat Sep 09, 2017 10:42 am
Check if you are getting voltage at the pump.First of all check the plug
behind the rear springs.If it is the pump try and get a genuine one
I got one off ebay last year and it didn't last long.
Re: No fuel pump
by odbod » Mon Sep 11, 2017 7:24 pm
I have now took the tank out and pump I shorted the pump out and did not work all so the pipe that feed the pump are totally claps so could not get fuel to the pump so I am now going to change the pump and pipes and the fuel sender unit as well
