Changing indicator arm
Just looked in Haynes book and it doesn't say anything about the airbag.
Disconnect the battery neg lead
turn the streeing wheels as necessary to expose the 2 front streeing column shroud screws
remove the 3 securing screws from the underside if the lower column shroud, then remove both the upper and lower shrouds
disconnect the wiring from the switch
depress the switch retaining clip and remove the switch from the housing.
Users browsing this forum: No registered users and 99 guests
