system 90 alarm help!!
System 90 is the name for a large group of security products from the Vauxhall accessory range. Have you got the OE alarm remote upgrade, a 902, etc... I work on the helpline so will be able to help you.
BTW, the alarm helpline number is 02476 375999 (for future reference) [img]/wink.gif[/img]
Trying to start the car with a flat battery wont bugger the things up - jump starting the car can though!
alarmbod
Cheers alarmbod,
Glad to know there is still a helpline,the number i had was 01926408208:now dead!
It IS a 902 and i was wondering if it could be repaired or a new one bought? (vauxhall dealers have been no help whatsoever).
I tried to start the car on a low battery and the solenoid just clicked in and out,think this caused some heavy back voltage which has wiped part of the alarm out,when it WAS working,it was spot on,together with a couple of of my own security mods to stop thieving gits [img]/smile.gif[/img]
Mark16v93
We did have a recorded message on that phone number for a couple of years, guess BT decided to close it down, cus I've not seen any letters from them asking for money for a long time!
First thing to check is to turn the ignition on, flick the switch on the dash into the 'auto' mode, turn ignition off, then open & close the drivers door. See if the alarm goes into a countdown and arms up on its own. If it doesnt, then you want to be having a look at the fuse in the red wire on the ten pin connector going to the main control unit behind the dash (if you dont know where it is pm me & i'll tell you)
If the fuse is ok, then just turn the ignition on, and see if pressing the alarm remote does anything then - if it does, then its a problem with the PSU inside the alarm - fatal Im afraid, but I can probably sort something out [img]/wink.gif[/img] The alarm has now been deleted by Vauxhall, so you wont have much luck at the dealers!
alarmbod
