on board computer
by 4x4Turbo » Tue Oct 12, 2004 11:46 am
i need to change the bulb in the trip computer is it easy enough to do an how do i get to the bulb??
cheers
olly
4x4Turbo
on board computer
by SukySaggi » Tue Oct 12, 2004 11:49 am
Remove the trim, pull out the computer. In the back will be a bulbholder. Twist and remove and replace bulb.
SukySaggi
by RobbieV » Tue Oct 12, 2004 11:53 am
<!--QuoteBegin-SukySaggi+--><div class='quotetop'>(SukySaggi)</div><div class='quotemain'><!--QuoteEBegin-->Remove the trim, pull out the computer. In the back will be a bulbholder. Twist and remove and replace bulb.<!--QuoteEnd--></div><!--QuoteEEnd-->
On mine the bulbholder is on the side, its a small white cap use a screwdriver and prise off, there you will see the bulb remove it with a small pair of tweezers and replace with new bulb [img]/smile.gif[/img]
by 4x4Turbo » Tue Oct 12, 2004 11:58 am
just had a quick look mines got the white cap on the side what sort of bulb is it?? can i get one in halfords or is is a special vauxhall one??
4x4Turbo
by RobbieV » Tue Oct 12, 2004 12:06 pm
Hi, go to your local Vauxhall dealer and ask for part number 9198599 (04e16 bulb 12v-1.2w) I got 2 for £1.34p [img]/smile.gif[/img]
by 4x4Turbo » Tue Oct 12, 2004 12:38 pm
nice one will do that
cheers
4x4Turbo
