credtop fault code 15 - cts
by jusser » Mon Oct 25, 2004 2:05 pm
I have the above fault code stored - 'Coolant temperature sensor - voltage high' - will simply replacing the cts work or do we think the problem could go deeper than that?
cheers
jusser
jusser
by SukySaggi » Mon Oct 25, 2004 2:59 pm
Me too :cry:
It's going to be one of two things.
1) The C.T.S. is shagged and needs replacing
2) There is a break in the one of the 2 wires that go to the C.T.S.
Do you know where abouts the C.T.S. is on the engine head?
SukySaggi
by jusser » Mon Oct 25, 2004 5:15 pm
No idea! Perhaps someone with epc will help us out here!
jusser
by Fraz » Mon Oct 25, 2004 5:56 pm
might help if we knew what engine were talking about here???????????
Starsky and...
by DaveQ » Tue Nov 02, 2004 10:21 pm
The CTS is on the left hand side of the engine as you look at it, under the hose that goes to the radiator...
Costs £23 from VX and so long as you wait for the engine to cool right down...its very easy to change...5 mins at the most [img]/smile.gif[/img]
Dave
From the title I assume you have a RedTop engine [img]/smile.gif[/img]
Also, if you have a multimeter, it should read about 1k5 cold and if you warm it the resistance should decrease slowly...
DaveQ
Users browsing this forum: No registered users and 109 guests
