Lights
by cally228 » Thu Dec 23, 2004 8:21 pm
I have recently fitted some lexus lights to my car but having fitted them, my brake light failure bulb won't go out, is there any way I can remedy this problem (without taking the bulb out!)
RE: Regional Register
by Fraz » Thu Dec 23, 2004 8:34 pm
well I fitted mine and the barke warning light works just fine. As does a few others that have them fitted. Could it be you have a faulty brake light bulb?
RE: Immaculate calibra turbo and parts
by cally228 » Thu Dec 23, 2004 8:43 pm
Well they both work mate, I'm puzzled!!!!!!!!!! :?
RE: Is it too much?
by Fraz » Thu Dec 23, 2004 11:29 pm
seem to remember someone had same probem, IIRC was something to do with the bulbs , changed them for new ones and it cured the problem
just a thought...you dont have a third brake light? (on a spoiler or in the back window)
by cally228 » Fri Dec 24, 2004 8:31 am
I do mate, but it all worked with that on, only went breasts aloft when I put my new lights in. :?:
by bigun » Fri Dec 24, 2004 9:34 am
Swap the bulbs mate. My old volvo turbo had the same thing. Turns out it measures the difference in voltage between the two bulbs and not if one is out. If one bulb is a different make or has been bashed about a bit it could see a difference in voltage between the two although they still work. Grab two new ones from halfords and give it a shot. Failing that make sure all yer earths are tight. Should be a relatively simple thing to fix.
Good luck
Bigun.
bigun
RE: no rca plugs on head unit
by Fostersice17 » Fri Dec 24, 2004 1:10 pm
Not led bulbs are they? If so you will either have to fit a resister,Or take the warning bulb out.
Fostersice17
fuel computer, fuel sensor calibration.
by Mac » Fri Dec 24, 2004 3:22 pm
Did you put the silvertech bulbs in or just coloured indicators mate?
Mac
by Fraz » Fri Dec 24, 2004 4:17 pm
I have the silvertec bulbs fitted, and the warning light works just fine
RE: Another broken sunroof
by cally228 » Mon Dec 27, 2004 8:25 am
Problem fixed. New bulbs all round. Jobs a good'un.
Cheers guys.
Users browsing this forum: Google [Bot] and 34 guests
