is my alarm on its way out ?
RE: Nissan Silvia - needs a bit of work!
by Col » Sat Jan 22, 2005 12:11 am
Quick question guys...
The standard alarm, when you turn the key to operate the deadlocks should the light on the alarm sensor flash rapidly or should it flash every couple of seconds ?
mine flashes rapidly, ive never noticed it before and am wondering if there is a problem ?
thanks in advance [img]/smile.gif[/img]
Col
RE: Alternator
by craigmcd82 » Sat Jan 22, 2005 12:52 am
I cant remember off the top of my head - But hopefully this will help!
craigmcd82
by tb303 » Sun Jan 23, 2005 10:27 am
hmmm. cool info. mine flashes repeatedly for the first 10 seconds and does not change even if i press the button on the cabin sensor. i suppose it is due to the bonnet switch missing. will put a switch in the bonnet and give it another try.
does anyone have pictures for the rest of the sensors please? where are the door alarm switches located? are they the same switches that put out the interior light when the door is closed?
also i took my car to a professional to install a new radio system. i think i've read in your manual that the alarm is monitoring also the radio. is it possible that there is an error there too now?
tb303
by Col » Mon Jan 24, 2005 12:11 am
cheers for that craig, looks like i have a fault somewhere along the line. ill have to have a proper look asap
Col
by jayl645 » Sun Jan 30, 2005 8:20 pm
hi,my led flashes with in the first 10 sec's i think it has a fault!!!,could it be the drivers door sencor because the interior light dosent come on when i oped the door but it works with the passenger side?,
and is there ment to be any thing behind the interior light as i have a round hole in my head liner about the size of a 50 pence piece,(strange) any help would be great as i need to get it fixed asap,
chears jay any quick fixes would be good
jayl645
RE: LEAK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
by Stupink » Sun Jan 30, 2005 9:17 pm
Short pins A and H on the diagnostic plug and it should flash out the fault codes to any problems on the LED
by jayl645 » Mon Jan 31, 2005 8:12 pm
thanks stupink ive got a fault code its 33 BO U KNOW WHAT THIS IS MY CARS A J REG 2LTR 8V standard alarm please help me people
jayl645
fault code help please
by jayl645 » Mon Jan 31, 2005 8:19 pm
sorry not 33 the code is 31
jayl645
What Size R They
by Stupink » Mon Jan 31, 2005 8:20 pm
hi.. 33 means that the bonnet switch triggered the alarm.. you should be able to clear the code with the button on the ultrasonic unit... if it keeps re appeearing i guess there is sommit wrong with the bonnet switch/wiring [img]/smile.gif[/img]
by jayl645 » Mon Jan 31, 2005 8:22 pm
just had a nother look and the code is 33 not 31
code 33
now even im confused
jayl645
by Stupink » Mon Jan 31, 2005 8:22 pm
oh .lol.. 31 isnt a fault code apparently.. not one i have listed anyway.
I wanna buy your mat !!!
by Stupink » Mon Jan 31, 2005 8:26 pm
ahh.. that makes more sense..hehe..
02 voicemail
by jayl645 » Mon Jan 31, 2005 8:28 pm
the code is 33 for the alarm i did set the alarm off by the bonnet switch today!!! ill press the button and try it again,thanks
do u know what the code 31 and 12 means(not for the alarm)i put a paper clip in a+b chears
jay
jayl645
by Stupink » Mon Jan 31, 2005 8:57 pm
12 is just the start of the process and 31 is just engine speed signal, so you will get that without the engine running.
hope your alarm stays clear for you [img]/smile.gif[/img]
RE: 02 voicemail
by jayl645 » Mon Jan 31, 2005 9:04 pm
thanks so i dont need to do anything about 31? (its normal) i thought it was guna cost a bomb
jayl645
