remote central locking
1 post
Joining wires
fitted the system 90 rcl kit last weekend + it works fine, although you have to be very close to the car for it to respond is this normal ? or low battery power, both fobs are the same. also is it possible to wire up the courtesy light to come on when you unlock with the fob [it does on the wifes vectra], + close the sunroof when you lock as it does the windows. oh yes thanks to whoever wrote the guide very useful, its a good idea by the way when drilling the hole for the led to use a small pilot drill first otherwise its easy to drill offcentre,resulting in an unplanned trip to the local scrappy for another blank. cheers [img]/smile.gif[/img]
jeffp
1 post
Users browsing this forum: No registered users and 41 guests
