Phase 1 chip Over Boost problem.
by gremlin » Mon Mar 14, 2005 5:14 pm
<!--coloro:black--><span style="color:black"><!--/coloro-->I have installed my Phase 1 chip from regal and plumed in a boost gauge and started to wind the actuator open. I quickly get to about 15psi over boost and the 13 psi standard which its meant to be but no mater how much further I wind the actuator it seems to be stuck about 15psi and not allowing me the 18psi over boost the chip says its capable of.<!--colorc--></span><!--/colorc-->
<!--coloro:black--><span style="color:black"><!--/coloro--> <!--colorc--></span><!--/colorc-->
<!--coloro:black--><span style="color:black"><!--/coloro-->Does this mean my actuator is old and duff or am I missing something silly!?<!--colorc--></span><!--/colorc-->
gremlin
by Dan Willis » Mon Mar 14, 2005 5:28 pm
Is it a standard actuator? It could well be that the stock one is not up to the job of holding any more.
Dan
by gremlin » Mon Mar 14, 2005 5:34 pm
yeah it is a stock one. i thought that might be the case i was just hoping it wasnt as that means a new actuator!
gremlin
by Dan Willis » Mon Mar 14, 2005 5:36 pm
If the actuator is stock, and original, then it's done a good job up until now as it is... and is probably due replacement.
Get a strong replacement anyway, £120 job. Then you'll have better holding of that boost after you've adjusted it up.
Dan
by Stupink » Mon Mar 14, 2005 6:09 pm
Yeh, i've run an uprated actuator on phase1, it works fine, the only downside is when switched off you force slightly higher boost.. so.... im not sure if its then safe to do so.. because your effectivly running the stock map and forcing higher boost??? so i would just leave the kit turned on, and be gentle with your right foot if you go that route [img]/smile.gif[/img]
