Brake pad warning light.
by Spearmint » Thu Jul 07, 2005 6:49 pm
Just changed my discs and pads today. Low pad warning light still on. The rear pads look low. I didn't think there was a sensor on them?
When I changed them today I managed to snap one of the sensors on the front anyway. So just cut them off and tied them back out of the way. Might just take the bloody bulb out of the dash!
Spearmint
by ROG » Thu Jul 07, 2005 8:09 pm
The sensors need replacing with each set of pads if you bother to fit them, if not If they dont go out from being cut off, try twisting the 2 internal wires from each sensor together, it works one way or the other i just cant remember which way
ROG
by Spearmint » Thu Jul 07, 2005 10:30 pm
Yeah, can remember it's the gain of an earth puts the light on. Next time I rotate the wheels I'll do that. Till then I'll live with that stupid orange light!
Spearmint
by Johnnytenpints » Thu Jul 07, 2005 10:49 pm
Mine have been joined together but one's come loose, so that's another little problem to sort out.
Johnnytenpints
by Blossey » Fri Jul 08, 2005 10:45 am
No sensors on the rears. Local motor factors do them for a couple of quid or so if I remember correctly, do it now or it'll drive you crazy, and then you won't have to explain it everytime someone gets in your car!
Blossey
by Spearmint » Fri Jul 08, 2005 10:48 am
<!--QuoteBegin-Blossey+--><div class='quotetop'>(Blossey)</div><div class='quotemain'><!--QuoteEBegin-->No sensors on the rears. Local motor factors do them for a couple of quid or so if I remember correctly, do it now or it'll drive you crazy, and then you won't have to explain it everytime someone gets in your car!<!--QuoteEnd--></div><!--QuoteEEnd-->
LOL. Yeah done that 5 times already. Which is a ball ache when you try and convince someone with no knowledge of cars and the like that it's perfectly safe!
Spearmint
by TommyC » Fri Jul 08, 2005 11:11 am
I Don't have that problem!! Sorted my wear indicators when i fitted these babys!!!!!!
TommyC
by Add_Gee » Fri Jul 08, 2005 1:08 pm
Same here, dam light, everyone asks what it is.
How much are the sensors and do you get the loom with them?
Add_Gee
by Blossey » Fri Jul 08, 2005 3:29 pm
For a few quid you just get the connector wire from the inside of the wheel arch to the actual brake caliper, about 1 foot in length. This is the bit that needs replacing, its a simple connector and 'should' be all you need. Will check invoice when I'm home tonight and let you know how much.
Blossey
by dj_smurph » Sun Jul 10, 2005 8:44 am
goto to autovaux get them in double quick time csnt remeber the price
dj_smurph
by midnightv6 » Tue Jul 26, 2005 5:31 pm
I have had similar problems....just forked out for new discs and pads all round.
The pad sensors were £7.50 from my local car spares place.
Looking to fit them this weekend...and hope it gets rid of my TC cutting in.
Will be cleaning the cogs properly too.
Is there anything else I should be checking at the same time????
midnightv6
by midnightv6 » Sun Aug 07, 2005 3:16 pm
Fitted the new bits this weekend.....
New Calipers for the rear.
New discs all round with pads and pad sensors.
Cleaned up the front calipers and wire brushed the TC cogs, then finished them off with a few squirts of WD40.
All is now working prfectly and no TC or ABS lights at all!
Yeeeeeaaaaahhhhhaaaaahhh![img]/biggrin.gif[/img]
midnightv6
by lammy » Sun Aug 07, 2005 10:54 pm
How did you sort the traction control?..couldn't do a simple guide could ya?..mines a bit tempramental to say the least and comes on when it likes!
SE9
by LewJamBen » Sun Aug 07, 2005 11:00 pm
Sensors from LMF Vauxhall cost me 13 pounds the pair.
01858 433599
LewJamBen
Price for front pad sensors from vauxhall
by big_gordy » Thu Aug 11, 2005 4:56 pm
The sensors cost £34.30 +vat for the Pair from Vauxhall
Part Number:- 90335784 this is for the 2.0 16v Ecotec
