Tracking and camber
Tracking and camber UPDATE
by ice » Mon Mar 06, 2006 6:43 pm
Ive just been to my local to get my tracking and camber checked and the camber is fookin well out on passenger rear and drivers front [img]/sad.gif[/img] the drivers front its just a little out but the passenger rear is nearly 3 degrees out [img]/sad.gif[/img]
bugger
im guessing something is bent, he had a quick visual look but couldnt see anything out of the ordinary [img]/sad.gif[/img]
Me is unhappy now
stu
ice
by Stupink » Mon Mar 06, 2006 6:46 pm
arg.. what is the ride height like that side in comparison? the rear that is, the fronts barely change camber when lowered.
just looking from the photo in your avatar it looks lowered?? if so it might have camber corrector bushes and they might have spun round.
by ice » Mon Mar 06, 2006 6:47 pm
standard shocks and springs [img]/sad.gif[/img]
ice
by Stupink » Mon Mar 06, 2006 7:06 pm
really does look lowerd, got a better pic?
by ice » Mon Mar 06, 2006 7:14 pm
<a href="http://www.corsasport.co.uk/board/garage.php" target="_blank">http://www.corsasport.co.uk/board/garage.php</a>
username to search for is: iceman
ice
by Stupink » Mon Mar 06, 2006 7:25 pm
hmm.. yeh, does look std there.
so do the sides measure up the same tyre/arch gap?
by ice » Mon Mar 06, 2006 7:26 pm
na if u look at it the passenger side leans in more
ice
by Stupink » Mon Mar 06, 2006 7:33 pm
the wheel sits higher in the arch?
missing bump stop, snapped spring, wrong spring, rusty top spring mount etc.
by ice » Mon Mar 06, 2006 7:36 pm
i wouldnt say it say any high compaired to the drivers side
ice
by Jambo » Mon Mar 06, 2006 9:08 pm
[img]/sad.gif[/img]
Could the garage not tell you what coloud be wrong??
Jambo
by ice » Tue Mar 07, 2006 12:37 am
only that the camber was out they said go see vauxhall as it could just be something simple like a bush
ice
by ice » Wed Mar 08, 2006 4:41 pm
had the tracking adjusted today so the toe is fine there is a problem with tht camber
front drivers is .2.16
front passenger: .56
now i need to get the camber sorted on the drivers side [img]/sad.gif[/img]
ice
Users browsing this forum: Majestic-12 [Bot] and 16 guests
