flutter in steering
<!--QuoteBegin-pas+--><div class='quotetop'>(pas)</div><div class='quotemain'><!--QuoteEBegin-->Bad as - not perfectly round, it gets little oval or egg shaped if you hit a curb or go over hole in high speed and million other ways. Cheaper alloys that are not good quality will be more sensitive and distort faster and easier.
Also alloys are cylinder in shape and you have two ends so one end can be perfect circle (one you see looking at the car) and other can be distorted.
<a href="http://imageshack.us/" target="_blank">
</a>
That is what is in my case - when I look at wheel balancing outer edge is rolling nicely and straight but when I look at innner edge it wobbles like egg.<!--QuoteEnd--></div><!--QuoteEEnd-->
This is what happened to mine, balanced them etc. I had to clean the engine one day to find an oil leak, while clean the drive shaft underneath the car i noticed when spinning the wheel while it was up in the air it was not round on the inside edge the outside was perfect, so purchased some new wheels problem sorted.
</a>That is what is in my case - when I look at wheel balancing outer edge is rolling nicely and straight but when I look at innner edge it wobbles like egg.<!--QuoteEnd--></div><!--QuoteEEnd-->
Paddy
I've just had new lower arms, front's balanced, tracking etc.etc.. spiggot rings in and OK.
The whole car starts to 'flutter' vibrate... whatever over 55 too... not through the steering but you can feel it through the steering wheel.
I gave one of our directors a lift this morning and he suspects the propshaft could be the cause (worn support bushes?)
Might be worth checking.
ice man
