Positive Camber
Positive Camber
by ice » Sun Apr 30, 2006 5:38 pm
What would cause positive camber?
Stu
ice
by Stupink » Sun Apr 30, 2006 6:05 pm
Forget the camber, buy yourself a decent phone [img]/tongue.gif[/img]
Didn't you say the camber is back neg now? you replaced the lower arms yeh? so it was probably just a bent arm.
by ice » Sun Apr 30, 2006 6:09 pm
i have a k750i its your fone lol the back is fine lol its the passenger front thats positive i didnt realise you cud get positive camber and the positive camber at the front is making the negative camber on the rear look worse than it is,
ice
by Stupink » Sun Apr 30, 2006 6:36 pm
I know you mean the fronts [img]/smile.gif[/img]
by Naz » Sun Apr 30, 2006 8:35 pm
well they have fix cambers on the callys. Which means if you get positive camber( I don't know what the std camber is) then something is probably slightly bent!
I know we had the same problem with Steve( bodgetastic) car in the past and couldn't get the camber right. At the end, I think he modified his wishbone so he could position the ball joint where he wanted it, thus correcting the camber?!!!
Also Gav/Cav16 all sell the adjustbale camber kit , but its a bit expensive.
Naz
by ice » Sun Apr 30, 2006 8:44 pm
naz i have the camber kit for the rears which isnt the problem its my front passenger side which sits at positive camber [img]/sad.gif[/img]
ice
Users browsing this forum: Majestic-12 [Bot] and 16 guests
