v6 wheel bearings
v6 wheel bearings
by ikledud » Fri Sep 01, 2006 11:15 pm
can some one please give me some info on changing the front wheel bearings on a v6 cally seen as the haynes bible dosnt cover the v6 lol i just dont wanna go about it all wrong incase they are different cheers
ikledud
by Rusty_CallyT » Fri Sep 01, 2006 11:41 pm
same as all the others chap, will need them pressed out and in tho iirc
Rusty_CallyT
by Phil69 » Sat Sep 02, 2006 12:02 am
As said above, they are all a press fit. If your really desperate they can be hammered but I wouldn't recommend it as bearings are not designed for shock loads and it can damage it.
by Fortuna » Sat Sep 02, 2006 12:56 am
Yes front wheel bearings are all the same across the range. I have changed a bearing and it was a pig! I would recomend you buy a used leg from a scrappy and take that to a workshop to have a new bearing fitted. They wont charge nearly as much if you took the car to them!
Fortuna
