Rear discs question.
by Phil » Fri Sep 08, 2006 8:59 am
I had a new set of discs arrive yesterday.
I noticed that the rear discs are different. The drum part of the new discs is about 10 - 15mm shallower (disc to wheel mounting face) than the discs that are currently on my car.
Will they still fit okay?
Surely the weel will sit further in??
Thanks,
Phil
Phil
by RobbieV » Fri Sep 08, 2006 12:12 pm
I dont think they will fit, I had the same problem some time ago the rear discs i got from Ebay were 60mm and i needed 70mm.
If you measure from the bottom of the drum the the disc i think it should be 70mm.
by Phil » Fri Sep 08, 2006 1:04 pm
doh. I'll have to send them back then!!
Phil
by mr_h » Fri Sep 08, 2006 4:52 pm
Dude i had the same trouble, i have a V6 with cally turbo brakes all round so i always have to get the turbo items instead.
mr_h
by Mark1 » Fri Sep 08, 2006 8:13 pm
I've got new discs for mine and just checked them and 60mm old ones 70mm:sob:
by Mark1 » Sat Sep 09, 2006 8:16 am
Just check Black Diamond part and I seem to have the the right ones.
by Will-Ni » Sat Sep 09, 2006 12:04 pm
I Had The Same Problem Before And Had To Return Them
Will-Ni
by Mark1 » Sat Sep 09, 2006 10:07 pm
<!--QuoteBegin-wil3086+--><div class='quotetop'>(wil3086)</div><div class='quotemain'><!--QuoteEBegin-->I Had The Same Problem Before And Had To Return Them<!--QuoteEnd--></div><!--QuoteEEnd-->
Oh bugger:frown:
by Will-Ni » Sun Sep 10, 2006 3:25 am
<!--QuoteBegin-Mark1+--><div class='quotetop'>(Mark1)</div><div class='quotemain'><!--QuoteEBegin-->Oh bugger:frown:<!--QuoteEnd--></div><!--QuoteEEnd-->
IT WAS ABOUT 2 YEAR'S AGO AND THEY WERE BLACK DIAMOND
Will-Ni
by Tim2001 » Sun Sep 10, 2006 7:37 am
The changeover on the rear discs is a right pain and is not very well defined by vauxhall. Basically you need to check the sizes of the discs before buying. Bought mine from wallace a few years back had them all painted up to match the calipers before i fitted them only to find they were incorrrect. Getting that hammerite of was a right pita.
Tim2001
by Phil » Mon Sep 11, 2006 11:17 am
Hi guys. Well, confirmed and the discs have gone back, £12.50 extra my expense, £10 there end extra too. - And a couple of weeks hold up too!!!
I have the 270mm discs too. It even has one more hole on the hub part over the 260mm disc???
Phil
