Rear Camber!
Rear Camber!
by PuppiesBalls » Sat Mar 17, 2007 1:52 pm
I lowere the back 40mm and now the wheels have noticable camber!
is there any way i can get rid of this?
PuppiesBalls
by Phil69 » Sat Mar 17, 2007 2:11 pm
Common problem on Calibra's when they are lowered. You can either live with it and be prepared to buy new tyres alot more often with the inner edges scrubing out very quickly OR you can get camber adjusting bushes to fit to the rear wishbones. There have offset hole through them rather than centred so that as they are rotated, the camber is adjusted at the same time. It won't correct is completely however it will help.
by PuppiesBalls » Mon Mar 19, 2007 6:57 pm
where can i get these camber fixing bushes?
PuppiesBalls
by Turbotez » Mon Mar 19, 2007 11:53 pm
Powerflex, i think there called that, there the best priced ones
Turbotez
by Phil69 » Tue Mar 20, 2007 9:08 pm
I know Regal used to do them but I'm not sure if they still do.
You could try Courtney sport as well.
