Discs (Help....)
by PaRiS GR » Sat Aug 04, 2007 11:42 pm
Hello
is now time to change my front brake discs. i was thinking to fit discs with bigger diameter but i have no idea what i can do. the size of my discs are 256.
i was told that i can buy the calipers from the turbo or V6 with discs from a VW corrado VR6 cause are 4 stund and 280 diameter but i have to use Spiggot Rings to align the disc correctly onto a 4 stud hub.
any ideas please......
Sorry for if i have done any mistake with my english but im still learning
Thanks
Paris
PaRiS GR
by Mark1 » Sun Aug 05, 2007 12:57 am
Have a look on here.................
<a href="http://www.lmfvauxhall.co.uk/store/home.php?cat=1306" target="_blank">http://www.lmfvauxhall.co.uk/store/home.php?cat=1306</a>
by PaRiS GR » Sun Aug 05, 2007 6:30 pm
Mark1 wrote:Have a look on here.................
thanks mate
PaRiS GR
by Phantom » Fri Aug 10, 2007 4:05 pm
yes what you say is possible, but I'm pretty sure the VW discs are 5 stud tbh which you'd have to have re-drilled, it's really about how much you want to spend
the brake upgrade kits from LMF are very good I have the 308mm kit on mine
Phantom
by PaRiS GR » Sat Aug 11, 2007 4:25 pm
Phantom wrote:yes what you say is possible, but I'm pretty sure the VW discs are 5 stud tbh which you'd have to have re-drilled, it's really about how much you want to spend
to be honest im a student and i cant spent a lot. i have already the calipers from v6 and im looking for discs.
PaRiS GR
