rear wheel bearings
From what I remeber you need to take the whole rear arm off which also means unbolting the rear driveshafts. Good time to check the bushes whilst you've got it all out. It's even a pain in the ar5e to press the bearings in/out as the arm itself gets in the way of the press. I seem to remember using a lopped off bit of scaffolding pole or similar to push the new ones back in (you'll knacker the new bearing if you push on the inner cage/race).
Definately a machine shop job if you don't have the right kit although I'm sure some have done it with brute force, ignorance and a gas axe...!!!
MickM
