rear hub help
rear hub help
hey guys came across a little problem 2day. Took the rear wheel off this morning bolts felt i bit weird when i got them off some were "threaded" i think the term is took a look into the holes for the bolts its looks a bit chewed up and my wheel nuts wont go back on properly. can anyone here help me on this one as im a bit stuck and i wanna try fixing it 2moro. cheers guys
casper81
Re: rear hub help
yea tried that i know i might be flapping over nothing just dont fancy my wheel falling of at the first corner lol. im going to buy 4 new ones 2moro see if that works after my dad telling me u can rethread the holes so i'll give it a go.
casper81
Re: rear hub help
If by chance you mean cross threaded, then a new bolt wont help..
it will probably require drilling and helicoiling to fix, normally around 25 notes a thread, to do this the hub will need to be removed and done on a bench set up for accuracy...local engineering firm will be able to sort..
RAINMAKER
Re: rear hub help
damn i hope not thats gonna be 4 threads needin done if so. i'll give that try first with the bolts if no joy then i'll go down that route
casper81
Re: rear hub help
had this on my se9 i bought earlier this year, cost involved was 20x25 as all hubs and threads had been damaged by previous owner..it was gonna cost the same to replace the hubs...dilema time i can tell you..
try not to force anything as it will only cause more damage..hope you can sort, best of luck.
RAINMAKER
Re: rear hub help
cant you just get a tap and run it throw ?
might be worth a try beter than £25 a hole
Re: rear hub help
bit of a problem there steve if its been crossed threaded or worse stripped then theres nothing to cut into so to speak...
helicoiling will drill out the hole one size larger and a new threaded coil is drilled into this replacing the old thread..usually this is done as i said on a bench set up/jig to get it all straight and perfect but costs..
RAINMAKER
Re: rear hub help
ive got one on the v6 that has crossed threaded think ill keep an eye out for a new hub then
Re: rear hub help
hey guys thanks for all your advice. managed to get the wheel back on with new bolts with a 1/4 turn at a time lol. will be looking for a new hub asap to fix it once and for all.
casper81
Users browsing this forum: Bing [Bot] and 37 guests
