Wishbone quickie
Wishbone quickie
by Robs-se » Mon Jan 12, 2009 3:00 pm
If giving the bolts a quick tweak to tighten is it best to have the wheel off the ground
or can it be done standing?
Re: Wishbone quickie
by rich_DTM » Mon Jan 12, 2009 3:01 pm
doesn't matter can do either!
rich_DTM
by vinny_69 » Mon Jan 12, 2009 3:15 pm
make sure you use quality tools,un like someone :roll:
if you run into any bother supertyres dunstable road did my pass side for 30 squid
by Robs-se » Mon Jan 12, 2009 3:26 pm
Why, what happened to you? When the mechanic did my right side one the pillock took out the rear bolt, then decided to reverse the car and wore away the inner lip on the bumper and liner, twot
by Stupink » Mon Jan 12, 2009 5:01 pm
As with most bushed suspension components its BETTER to tighten them ON the ground in the resting position to prolong bush life.
by vinny_69 » Mon Jan 12, 2009 5:26 pm
Robs-se wrote:Why, what happened to you? When the mechanic did my right side one the pillock took out the rear bolt, then decided to reverse the car and wore away the inner lip on the bumper and liner, twot
the big 16mm nut was done up so tight i went through most of my tools trying to get the fecker off and in the end gave up :oops:
by Robs-se » Mon Jan 12, 2009 9:18 pm
Been there myself, trashed many a ratchet, spanner socket, screw driver
by matty0785 » Mon Jan 12, 2009 11:01 pm
impact socket and 3ft power bar always works 8)
or breaks captive nut ooopppssss :shock:
by Robs-se » Tue Jan 13, 2009 9:36 am
Already broken the captive nut, the thread got screwed so had to punch a hole in the floor and use a longer bolt and self locking nut :(
bit of a sh!tty job as well
by Calibra_Mike » Tue Jan 13, 2009 6:33 pm
I find a blow torch sorts out nuts/bolts that wont budge...
by vinny_69 » Tue Jan 13, 2009 6:36 pm
i was lucky enough to only have to pay for the off side to be done :D
the bloke who smacked me car the other month paid for the otherside :mrgreen:
by calibratim » Wed Jan 28, 2009 2:52 am
had the same
calibratim
